- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Nice magsAnother pic
Taylor, since you asked, the old GM fuse panel had some hidden features. You can easily see in @heartbraker666 picture the 3 vertical fuses at the bottom are key on switched. Hidden feature #1: The radio will not work if the backup lights have a short and burn the fuse. This is a safety feature to let you know you have no backup lights.so wired directly to the battery sounds like they werent using the Radio tap on the fuse panel. @Turbo4whl were you an expert on the fuse panels? Someone here is very knowledgeable. Im thinking the switched ignition is the tap, and the fuse itself is the constant.
