cbrown5385
- Apr 11, 2023
- Mass
- Corey
- Suburban 1500
So I’m having fuel supply issue. I’m thinking I have a plugged fuel supply line. I have an electronic fuel pump mounted on the frame.
It was running fine then slowly started supplying less and less fuel until finally supplying none. I swapped out pumps and still same issue….. im
Think something is plugged form the pick il in the tank to the inlet side of fuel pump…
Best way of going about this? Already has All new rubber lines from the sending unit to the fuel pumped. I was going to try and charge the line with air and see if there was free flow?
