Robert Bare
- Sep 13, 2020
- MT
- Robert
- k20
Yes,no, maybe,lol. Just a retired mechanic here, worked mostly on foreign and GM over the years, by choice, 3 GM dealers.
On "untouched" older rigs, the spacers were "almost" always under the cross member. Never got a straight answer as to why, always assumed for frame flex. However, was taught always put them back the way you found them, by GM??
SO- a story, but true. Dealership, brand new suburban,4wd. Strange vibration, only at certain speeds and conditions. I watched this drag out over a 2 month period, as I was currently their Datsun mechanic. So, checks with the vibration analyzer. They send rear driveshaft out, to shaft shop. Still the same. Swapped shafts from other truck, the same, got a new shaft from GM, the same. GM Tech line contacted many times.
So after another month, as GM's traveling tech guy was very busy, he showed up. Goes for a ride, with the Vib, analyzer. Has them put it on a hoist, looks at the cross member, shakes his head, tells them to move the cross-member spacers from below to in-between member and frame. Ask him why he is shaking his head, his reply, "don't they teach this at the GM classes anymore??" So, after I'm done laughing, vehicle is road tested many times, him, GM mechanics, and shop foreman, it is perfect, vibration free. He is the one that told me put them back where you found them, as they may have been swapped for a problem, at the assembly line testing, or another dealer. SO take it for what it is worth.
BTY, from real experience, they do allw the bolts to come loose easier in sever off roading and such, as has happened to my plow truck several times, up here in the mountains, IF they are below or above the cross-member. I gave up, left them out, use bolts with lock-nuts, as in double nuts, no problems since.
Oh, the subby was a 90 or 91, best as I can recall.
