82sbshortbed
Fuckemall!!
- Mar 1, 2018
- SE Texas
- Doug
- 1500 shortbed, 1500 longbed
Put the 82 on ramps so I could check out the transmission leak. Got side tracked and never got under to look. If it doesn't rain I look after work today. I didn't even notice how much fluid came out until I pulled back in the driveway. It's dripping off the pass side where the lines go so I'm pretty sure that is where the problem is.
I was looking behind me when I backed out. Then left to go around the block and missed the big oil stain. Can't believe how much came out and I missed it. Glad I didn't mess it up with a longer drive. Lol
There's only a gallon in there? But the transmission never acted like it was low on fluid. Even got on it pretty good on the way back and broke the tires loose. Got lucky I guess. Lol
