randomTruckKid
- Feb 26, 2024
- Rockport tx
- Brian
- C10
Any thickness or one you suggest? I don't know what would be considered good.... yet.I'm thinking a front bar will do wonders, even if it's just a stock C10 bar. You've increased the center of gravity by a large amount and that will have a big effect on the handling with a stock or near stock spring rate.
One reason I suggested an aftermarket front bar though is because you can upgrade to end links, rather than using the stock end bushings that are always binding.
