Help with grinding/whirring sound!
cmyhran
Minneapolis
Chase
My square (1986 k10 silverado) makes a grinding/whirring sound when the axel/wheels are rotating. It almost sounds like something isn't properly lubricated. The sound gets faster/louder the faster I drive. The sound slows down, gets quieter when I slow down, like at a stop light. The sound is directly related to how fast the wheels are spinning. And it seems to get worse when the truck is hot. I don't hear it if I haven't driven for a few days or first thing on a cool morning.
Any idea what this could be and how I might fix it? The sound happens whether I'm hitting the brakes or not! I'd add a video with the noise but the files too big....
cmyhran
Minneapolis
Chase
Here's a link to a video with the sound! This is coming to a stop.
Any help greatly appreciated, I'm new here!
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
First check would be wheel bearings,based on your description.
^^^^ This
Except a dragging brake pad or shoe would be my actual first check and bearings would be second. Only because brake issues can be seen without disassembly of the hubs.
Auburn, Washington
Sound doesn’t change when brakes applied. IMO that mostly rules out brakes.
OP, gonna have to do like anyone else would. Take wheels off and start diagnosing.
If you’re stumped after actually inspecting the things that spin on the truck (wheels, driveshafts, engine accessories) then provide some more context/history for us innnerweb mechanics. lol
scrap--metal
MN
Calvin
'85, '81
K10, K20
I had a set of locking hubs go bad on me. That made a grinding/whirring sound directly proportional to wheel speed. Replaced them and the truck was happy again.
tsgs84
md
Timothy
Drive the truck for awhile but only until you hear the noise for 5 minutes or so then slowly stop and feel your hubs, if a wheel bearing is going bad that hub will be hotter. Also remember that the front brakes do most of the stopping so judge accordingly.
77firstsquarebody
Tennessee
Justin
GMC C25
350 V8
@cmyhran I am having this same issue. Can you point me to the location of your solution?
3 Ton
Pacific Northwet
Fred
1978-79 78 body, 79 gearing
K-15 Suburban
Jack each wheel up, hands at 12 and 6, and see if you can move the front wheel back and forth.
Whiles its up you can spin it and check for wheel drag. Dont think so or it would shutter when stopping.
77firstsquarebody
Tennessee
Justin
GMC C25
350 V8
I have ruled out wheel bearing. I have checked everywhere I can see with my truck on a lift. The noise only happens in Drive and not reverse.
saltdog
US
K20 Suburban
A bad rear pinon bearing could have the same behavior
JUKA
