beady
- Jul 20, 2024
- Tidewater/Northern Neck VA
- Mine
- R20
The truck starts and runs on starting fluid.You need to check the fuses,in the box checking for power on both sides of the fuse Technically that's not checking the fuses it's checking the fuses and power to the circuit. But a good fuse with no power to it still won't get the job done.
I don’t know which circuits are powered with the key in each position offhand. Does every fuse have power to one side of it all the time?
I’m new to this platform so don’t have the background knowledge of reading posts for decades like on my BMWs and 300zx.
So ecm 1 fuse connections have power to the inner leg with key ON and power (12 v) at both fuse terminals metered on the back of the fuse in ON.
Ecm b has no power at either of the fuse block terminals (metering the actual fuse block terminals with fuse pulled) in ON.
