Dana 60 BOM # confusion
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
Got a 60 front I'm going to pull out from the pile and start getting ready for the burb. Was doing nothing and looked up the BOM and can't find it on multiple websites, even BillaVista.
What I read is 610033-2
Even tried 0038, 0088, 0083...
Anyone?
Imho, the numbers aren't important at all. Is it passenger drop? Is it Chevy or Dodge perch spacing? Single wheel or dual wheel? Have you pulled the cover to verify the ratio?
Other than verification of the ratio, the rest of that is easier to see than looking up numbers, imho.
SquareRoot
Exactly. It needs an oil change anyway.
Jawzjeep
Washington
Joshua
Suburban
I'm more interested that the number doesn't show on any of the sites that list BOM's I checked.
No oil in it, no knuckles or gears. All that can change.
I've got another place I can check. They're a little irate at times but I'm sure I'll get an answer.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Anyone?
Lucky!
nvrenuf
Mobile, Al.
No knuckles as in missing the outer parts or everything on the ends of the tubes has been cut off?
Got any other pics of the axle?
squaredeal91
Greg bush
1991 SB
I think what he's meaning is their empty on fluid. That's the impression I got lol
nvrenuf
Mobile, Al.
Yeah, that's entirely possible. I was just thinking that since he couldn't find the BOM and if the housing is truly incomplete it could possibly be from an equipment application.
geardaddy
st. paul mn
mike
several
Anyone?
1977-1/2--1978 chev k30 4.10 ratio
Thank you folks I appreciate it. Not sure why I couldn't find that, dang it.
If you ever want to ID another axle, These are spicer's lookup manuals for 1967-1998 or something, but they split at 1978
I dont know how long those links work, but there is a download button in the upper right hand corner
They are numbered
"x510-8DSD" and "x510-9DSD" respectively, if you cant use the link or need to find them.
from page 3 of x510-8DSD
How to Use This Catalog
This catalog contains applications and part listings for front and rear axles which fit vehicles from model years 1967-1978. For information on model years between 1978-1998, please refer to catalog X510-9DSD.
For miscellaneous models from years 1979-1984, please refer to X510-7DSD.
Darksim171
