molus
- Jul 12, 2023
- new zealand
- morgan
- k20
My doors have been replaced at some stage unfortunately. There is nothing there.The vin plates went away in 1979, when the VIN moved to the dash for the 1979 model year, just containing the VIN and continued up there until present day pretty much.
So an 83 should have this on the door-
This is the only thing I can find on the vehicle.It's either 6600 (base) or 8600 with RPO C6P.
www.gm.com/content/dam/company/no_search/heritage-archive-docs/vehicle-information-kits/chevrolet-trucks/1983-Chevrolet-Truck.pdf
Do you have the SPID label in the glovebox?
K
Definitely have the C6p, the spare tyre was a 235/65/16. Larger drums and 56inch 8 leaf. 4.10 ratio.If you look through the GM document posted, you will be able to get an idea of what you have.
Standard K20 (6000 GVW) should have 5 leaf rear springs, 3.23 ratio axle standard, and will have load range C or D tires
C6P option (8600 GVW) should have 8 leaf rear springs, usually 3 leaf front springs, 4.10 ratio axle standard, and it should have load range D or E tires (most likely E)
The only way to do that since everything is missing from the truck is to email the GM Heritage archive at [email protected] or fill out this form here: https://www.gm.com/content/public/us/en/gm/home/heritage/archive/archive-form.htmlDefinitely have the C6p, the spare tyre was a 235/65/16. Larger drums and 56inch 8 leaf. 4.10 ratio.
Unfortunately I have to prove to the vehicle entry certifier in NZ what it is with some form of written identification.
I think I’ll do that. What was the options of payment. Could be a bit hard from the other side of the world.The only way to do that since everything is missing from the truck is to email the GM Heritage archive at [email protected] or fill out this form here: https://www.gm.com/content/public/us/en/gm/home/heritage/archive/archive-form.html
They will charge you $50 USD and then you will get emailed the original VIN sheet and original vehicle invoice that calls out all factory options and installed components from when it was originally produced and shipped to the first dealer or POS(point of sale). I got mine within about a week of sending in the filled out form.
