Laqota
- Apr 16, 2024
- Joplin
- Jerame
- C10
Visual Illusion from using my Wide angle camera and the amazing amount of surface rust on one side. I measured, they're the same size in each cylinder (Possibly rebuilt before badly? It looks freshly honed)Is it me or does one of the combustion chambers look different than the others?
This was my my grandfathers truck, it was in a used car lot, probably around 60000 miles and never ran since the early 90s because of a major vacuum leak, which he got it repaired by replacing the Manifold Vacuum Port on the Intake. He bought it in 2009 and believe it or not, did frequent oil changes. I asked! The old owner just didn't take care of it within' that time frame.How many miles on the engine?
New head and intake gaskets won't hurt a thing.
Have a machine shop check out the heads too before you put them back on.
They do crack.
The meter says 700k, but I don't believe it. It drove a bit to get home and didn't change, and I've been "driving" it up and down our street to make sure it was functioning correctly after anything I did (such as, I deleted my Vacuum. Didn't seem necessary, car lot people deleted EGR anyways). Meter has stayed at the exact same number, never moved an inch.
Sounds good. I got few guys I can look to, I've been looking to one guy and he's been real helpful. Lettin' me borrow his Torque wrenches, hoists if I need it. He said he's getting me some head gaskets, and when I showed him this one he said "This is too thin, probably stock. I'll get you some gaskets". I've seen the engines he's built and I'll probably be getting copper ones.@Laqota, bummer dude. I’m not an expert at reading engines, but it certainly appears to be eating coolant on #5 and possibly others.
If it was a smooth running engine save for the coolant leak and you have more time than money, I’d consider cleaning up the head and block, straight edge it and check carefully for cracks. Get new top end gaskets and go for it.
Hard to say what’s best, based on your budget, time and how you plan on using the truck, but an old crusty 305 is not a motor to stick any real money into.
This engine is more of a project because I'm not afraid to buy a new engine if this one blows. This is just gonna be a go to job, come back home from job, relax. My current quote for a rebuilt 350 is $2000 starting which isn't bad compared to how much it costs for my dads ol' Ford F150 engine.
