Parasitic draw
buddhabelly
usa
Jarrett
k10 (scottsdale)
Learned a lot on this site and could use some help:
84 Scottsdale, swapped with a 1990 350, dual batteries. Power draw. Door light is clamped shut and hood light is removed, still getting 13v draw on battery. Went through all the fuses in the bussing under dash twice. What am I missing?
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
It's a common goofup to measure draw with voltage. It doesn't work though. It's kind of like saying that you're 6 gallons tall, or that you weight 50 inches. If you're using a DMM with really high impedance, they'll always read close to battery voltage if you put them in series with the battery cables.
If you don't already have one, get a meter that measures amperage. Take the reading in series of either the positive or negative battery cable. That'll give you a draw reading in amps.
There's a ton of good youtube vids on how to do it.
Joe
fast 99
Spokane, Washington
Another way is hook a test light in series at the battery post. Preferably on the negative side. If it lights up there's a draw. A common non-fused draw is the alternator, disconnect it.
buddhabelly
usa
Jarrett
k10 (scottsdale)
The sad part is I’m a licensed electrician. DC is not my forté.
buddhabelly
usa
Jarrett
k10 (scottsdale)
Can you explain that like I’m 5? I have a meter, and I also have a cheap 12v tester. Which lead goes where?
buddhabelly
usa
Jarrett
k10 (scottsdale)
Update: I tested my alternator at oreilly and it passed. I bought a starter and upon install when I turned the key it fired right up but the starter would not stop “starting” I panicked and disconnected the battery cables and have been sulking for hours since. Edit: my batteries are brand new and both have 13v
fast 99
Spokane, Washington
Doesn't matter as long as it is inserted into the circuit.
On the starter sticking, it is either a bad starter or electrical such as the ignition switch.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Hot wire on starter is touching solenoid post.
fast 99
Spokane, Washington
As an electrician this might help. I use a shunt with Fluke on the millivolt scale for draws. It allows anything to be turned on or off except starter. Max draw is .05 millivolt across the shunt.
buddhabelly
usa
Jarrett
k10 (scottsdale)
This forum is so dope I wish i joined a long time ago. Could’ve saved a lot of headaches
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I like that shunt - where did you get it? I have used an antique DC ammeter to hunt down phantom draws in British cars (it is a relic from my grandfather which he used back when houses were fed with DC current - measures up to 300 amps) - that shunt and a modern digital meter would be a lot easier and safer....
fast 99
Spokane, Washington
Picture is from Amazon. But the one I use has only one bar, cheaper. Don't think that really matters. Made leads for the battery. Good idea to use the neg side, won't short to ground. Below is how it's used.
Uberbeans
Florida
Charles
K-5
Never used this before and I'm having the same problem. Where are you putting these clamps? Between suspected circuits that have a draw of on the battery leads? Sorry if this is a dumb question.
Disconnect negative battery cable. Set digital Mulitmeter to read "A". Connect one lead to the battery cable, connect other lead to the negative terminal on the battery. If you have a parasitic draw you should see something more than 0.5A on the meter with the key off. Start pulling fuses one by one and look at the multimeter after pulling each one. When the draw drops below 0.5A, you have found the circuit that has the draw in it.
fast 99
Spokane, Washington
Thats an option but have to be careful the load doesn't exceed the fast blow fuse. Last I knew they were about $10. After buying several I use the shunts.
Remove negative cable, one clamp on the cable other on the battery. I say negative because no grounding issues. That is unless it is an older British car. In that case positive side.
brentjo
