horn(s)
Ken B
indiana
ken
my 81c10 has 2 horns but only one is working....looking for a stock replacement anyone looking to get rid of one.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
What one you need? There are different toned ones. They should designate somewhere on them. Might help when looking.
Have you tried spraying penetrating oil into it and letting it soak for a while? Often times you can bring them back to life by doing that, then applying 12v to it several times until it starts to sound normal. If it starts working, it will probably sound funny for the first several honks.
squaredeal91
Greg bush
1991 SB
That's cool! Good to know
I guess I should add, that only really applies to the older GM horns used into the 90's. The ones used after that are pretty much just completely dead when they stop working.
Ken B
indiana
ken
bucket you got a "juice" of preference wd 40, pb blaster or are they all the same
I've typically always used JB-80 or PB Blaster, since that's usually what I have on hand.
I normally just blast some lube into them and then try honking a minute or two later.
Turbo4whl
Downingtown, PA
Wayne
If the horn buzzes when hooked to power, you can fix it.
Horn off the truck, add 12V and a ground wire. While conected to power, tap the horn on the concrete. Horn will start to beep after a couple hits. Couple more hits it will get louder. Stop banging.
ajdouble
