2002 RAV4 massive oil leak
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
Hopefully someone here has some insight. Back in January, my Rav radiator sprung a leak. It got parked until a couple weeks ago, because I have my truck and I drive my patrol car daily. So I finally got around to putting a radiator in, and that went smoothly. I pulled it up to the driveway and let it idle for 10-15 minutes to check for leaks and then shut it down. The next day I started it up to run some errands. I got less than 3 miles down the road and stopped at a stoplight. That’s when I noticed smoke rolling from under the hood. I pulled over and popped the hood. I saw oil running down the transmission and had a pancake sized oil puddle in less than 30 seconds. So I high tailed it back home and parked it. But, I can’t figure out where it’s coming from. It’s a front wheel drive, so the motor is mounted sideways. It was running down the front and rear of the transmission, so it had to be coming from that area. Any ideas? I zoomed in best I could to show where it’s leaking. You can see oil pooled up on the transmission. And yes, it’s motor oil.
bigcountry78
James
K10 Custom Deluxe
I guess I should mention, it’s the 2 liter 4 cylinder, automatic.
I'm not familiar with those later ones, but for it to be leaking that bad, it must be from somewhere with pressurized oil. Like maybe a pressure sender or a solenoid/valve for the variable valve timing.
bigcountry78
James
K10 Custom Deluxe
Well, that’s a start. I’m hesitant to start taking it apart, right now I can still crank and move it out of the way if I need to. Once I start taking stuff off, moving it around gets a whole lot harder. If I can’t fix it cheaply and relatively easily, then I’ll probably just park it and save money on insurance.
bigcountry78
James
K10 Custom Deluxe
Just another picture I found of the location of the leak.
350 w/203
IIWM, I'd top off the oil, spray down the motor with engine cleaner and hose it off. Let it dry and have the SO start it up while you watch under the hood. Just my 2 cents.
I'd take a closer look at this doohickey here:
It screws in which usually means there's oil pressure associated with it. Also, the puddle seems to form directly below it.
bigcountry78
James
K10 Custom Deluxe
Alright, I’ll see what’s going on with that thing. Maybe it’s that simple, a cracked sensor or blown seal.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I've seen sending units leak through the connectors before. It comes up through the sending unit and out of the electrical plugs. The connector in the back on the top right looks pretty greasy for an electrical connection.
bigcountry78
James
K10 Custom Deluxe
I’ll check that out too.
bigcountry78
James
K10 Custom Deluxe
Well. I ended up taking insurance off this thing until I could get around to it. I ended up hauling it to my dad’s house, and he took it to a nearby shop. He said it started getting hot and was low on coolant when he was taking it over, which was strange since it had less than 5 miles on the new radiator and I know it was full. The shop did their thing and found out that it was a bad head gasket. So it’s going to be around $1500 to fix, which I really don’t see putting that into it. Could probably replace the engine for 3k, but the car isn’t worth that. So, just thought I’d drop an update on it.
justhorns
Denver
Lee
Do a compression check and verify the blown head gasket.
bigcountry78
James
K10 Custom Deluxe
I may, just to verify. But, my dad said it was smoking on top of the low coolant so that’s consistent with the head gasket. I’m not really sure why it was forcing oil out though…
OurDually
