AC Clutch Cycling Switch
Magna86
VA Beach
Magna86
Chevy 350
Does anyone have a source for the AC Clutch Cycling switch besides LMC? I didn't see it on Rockauto or AutoZone. Or a good part number I can search for?
Thanks
350 w/203
Try Vintage Air.
fast 99
Spokane, Washington
AC switches are listed under switches not AC on Rock auto. If it's an original 76 system believe they had thermal limiters and bulbs.
Let me try this again. My truck is a late '75, and by that time they had switched to a CCOT system. I assume your '76 is the same.
Go to Rockauto.com and pick your vehicle
then "Electrical Switch and Relay"
then "Refrigerant Pressure Switch"
There are multiple choices for the switch.
Rickf
Grafton NH
1974, 1954 & a 1937
Mr. Bezos is sending me a 134a type switch tomorrow, four seasons part #36675
Magna86
VA Beach
Magna86
Chevy 350
This is the switch I think is bad. I touched it and it can apart in 2 pieces. Still have to check with a test light or meter. Found it on Rock Auto under switches thanks
OurDually
