Washington
They auto-reset after about 1 minute. The ones built into the motors reset after they've cooled off.
Thank you! Well this one hasn’t auto resetteded itself in a month so I’ll take that as a sign I still need to remove the motor and regulator….fccck.
mxer147
Colorado
Jack
k20
My painting skills are subpar, at least I am consistent with the orange peel, amazingly no bugs, a lil dirt, a couple fish eyes and no runs. Something positive, the body work actually looks pretty good. Glad to have this mostly checked off, the white on the bottom should be fairly easy since I plan to use some bedliner spray along 4-6 inches from the edge. The next hard part will be the hood since it’s got some minor hail damage to repair.
incubus2432
Grafton, Ohio
Shekkie
Picked up a used Weather Guard toolbox today. It’s light enough to remove when I need the space but gives me secure storage for stuff the rest of the time. This is the “deep” version so it barely fits. I woulda preferred the standard size but it was a deal I couldn’t pass up.
Shorty81
Baby Boomer
North West ohio
Darren
ORANGE is AWESOME!!!!! But I am a little bias....
FireTruck1984
Michigan
1984 and 1984
Looks great! What would really set if off… a set of Bed Rails, I have 2 New sets and 1 Restored set ready to go ! Jus something to think about. -Ted
Camar068
10 yrs Air Force
Installed led strip lights under the bed rails. Put a piece of hall inch rubber hose to run wires thru. Turned out pretty good. The only one visible is the one on the front of the bed. Put some heat shrink wrap on the section that ran through the tie-down holes so light wouldn't shine out of the holes.
Good idea, may do something similar to this with the floor mounted wench :Jedi:
Shorty81
Baby Boomer
North West ohio
Darren
Thank you Ted. I'm going to saw up some white oak side boards, since I'm in the hardwood business. I like that look on my ole' country truck!
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Pictures of the bed!
No wait! That doesn't sound right either! :eek:
I just wanted pictures of how well the lights work.
Oh gawd. How did this go sideways? :oops:
Here ya go pictures of my TRUCK BED at night. They're pretty Brite. You can definitely see to load or unload stuff in the dark. I'd like to see how it looks going down the road. Pretty sure that you could see it from a good distance.
My phone camera is pretty crappy but it is what it is.
Nilight 3PCS 60 Inch RGB Truck Bed Light Strip Kit 270 LED Neon Accent Lights with RF Remote On Off Switch Splitter Extension Cable for Cargo Pickup Truck Camper RV SUV Boat, 2 Years Warranty https://a.co/d/hi0cwO1
Here's the link for the lights
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Do you have it wired up to the cargo light switch in the cab? If not that would be cool.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Verrry nice!
Thank you.
82sbshortbed
Fuckemall!!
SE Texas
Doug
No I wired it in to the fuse box. It comes with a switch to turn off and on. I put it on the kick panel with velcro in case I need to remove it.
Then ran it under the seat and out the back of cab. That black box is if you want to set it to music. It has a hole in it so you need to keep it out of the rain. It's also velcro down to carpet. The rest of the connections are water proof tho.
I thought about wiring it to the parking lights but, thought this way was better.
Obullard74
