LS swap transfer case options?
YJPete
Saint Paul, MN
Pete
V1500
I am starting an LS swap on my 83 K10 reg cab short bed. I haven't picked an engine or transmission yet but I'm leaning towards a newer engine with a 6L80 or 6L90 transmission. I'm looking for transfer case options. NP241C has the passenger side drop I need, what do you think, good/bad? Atlas? What are you guys running? It's going to be a sunny day daily driver. Thanks in advance.
either get a 4l80 and then use any 32 spline passenger drop TC, or you will need to use whatever TC comes with your 6L80. If you get a 6l80/90, you will need to get a billet front covered torque converter. 83 was a year or two too early for you to be able to just reuse your stock NP208 I believe. If you get a 4l60e with your engine, you could likely just bolt it right up to your existing TC depending on what your current trans is.
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
I used a 2005 5.3 4l60e with a NP241C from a 1991 Jimmy. The NP241C came off a 700r4 that is the same length as the 4l60e, so it bolted up like factory and the front driveshaft is the correct length.
YJPete
Saint Paul, MN
Pete
V1500
Thanks for the advice. I like the idea of a 2003-2012 drive by wire 6.0l with a 4l80e, after some thought I don't think the extra two gears are necessary. The truck came with no drivetrain, so I am starting with a blank slate. How do you think a NP241C will hold up to a 6.0/4l80e combo?
SquareRoot
If it's gonna be a sunny day, daily driver as you say, I think your'e getting kinda anal on the amount of gears and strenght of the t-case don't ya think? If it's gonna be a Mall Crawler, forget the T-case altogether and enjoy the improved gas mileage. Heck, you might be up there in the elite 12/13 mpg club. Of course I'm just messin with ya. Maybe
sparky77
