- Aug 19, 2010
- Kansas City, Mo
- Jacob
- C10 longbed/R1500 Burb/R3500 Dually
Intro and info about the rig
About 6 weeks ago I bought my first Jeep and now have spent the last 6 weeks trying to learn as much about Jeeps as possible. At my roots, I'm a GM guy but have always wanted a Wrangler and TJ was as new as I wanted to go. Found this, it was overall very solid and ran well so I jumped at it. She's a 5 speed with the 4.0 and 190k on the clock so she needs a freshen up but has good bones.
Only real mods it currently has is a 4" Skyjacker lift on 33's and a couple Kicker subs in the rear with an aftermarket head unit. Does have LED headlights but not sure that's really a mod.
The audio doesn't currently work because the previous owner said a couple RCA's melted. So I've already ordered a new head unit and new RCA's to get it back up and running. Once it's warm again I'll dig into that and figure out why the RCA's got hot. Seems super odd but maybe a grounding issue?
I also grabbed a couple of replacement seats out of another TJ. See the pics. My stock seats are pretty roached LOL I also have some surface rust on the floors (NO HOLES!! ).
I've also got a couple new front fenders on hand to replace the rusty ones that are currently on it.
I've grabbed replacement Skyjacker shocks as it looks like this lift has been installed for a while. I'll also be replacing the sway bar end links and lower arms to freshen things up below.
All the body mounts look good except for the ones right in the middle about where the steps would normally be so I'll have to give that some attention there pretty soon as the body mounts are essentially gone and there is some rot that needs fixed. Luckily I stumbled across a patch kit that has some replacement pieces for that area so that must be a common issue. Once that's done, I also tracked down some steps to put back on. My wife and younger kids have a hard time getting up into the ol' girl so steps are required LOL Main thing for me was mechanically pretty decent and frame in good shape (which it is).
Plans
Overall refresh of everything
New Tires and Wheels. I'll most likely stick with 33's but may move up to 35's if the deal is right
Window Tint
Get audio working again
Exhaust
"Big 7" Upgrade
62mm throttle body upgrade and "cold air" intake
Fix exhaust on rear part of body (see pics)
.....and whatever else hits me as time goes. I'm still learning a lot and just looking to have fun with it while daily driving it.
Pics
Plans
Window Tint
Exhaust
"Big 7" Upgrade
Pics
