Steering Correction
Brysonsproject
Washington
Bryson
Chevy K20
I'm working towards installing a 4 inch lift on my 1978 K20 and just wondering which option to go with between a dropped pitman arm and a raised steering arm. (I've heard the raised drag links are junk). Also, I've heard that with a 4 inch lift I probably wouldn't to lengthen my driveshafts, but would it we smart to put in a 1 inch driveshaft spacer on both driveshafts just to be safe?
Thanks!
SquareRoot
Thanks!
What's a driveshaft spacer?
Craig 85
Nashville, TN
454/TH-400/NP205
K20 I'd go with a steering arm, it will level out the drag link better than the pitman arm. I've done 3 truck that way. I never needed to add to the drive shafts on a 4" lift. I would rather lengthen a drive shaft than run a spacer. The spacer would make the U-joints bind sooner, especially in the front as you have created a steeper angle on the drive shaft.
These were 4" lifts on my old trucks. No modification to the drive shafts. On the one truck I did a 6" on, I did have to modify them.
Craig is spot on. Go with the steering arm for a 4 inch lift and skip the spacer. The spacer "can" be beneficial with the longer trans/adapter/case combos used in the 80's, but may cause binding with a shorter combo like what was used in the 70's.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I've never heard of a spacer for the rear shaft, only the front. Huh.:confused:
Old Guy Bill
KY
Bill
I’ve got the drop pitman with a 4” lift kit on my ‘78 K20, it all came together from ORD. The link is at a fairly steep angle, I haven’t gotten to drive it yet, but I’ll evaluate the steering when I do and make any changes and or adjustments then.
When it come to driveshafts you can’t just guess. TC, and pinion angles, along with the slope of the driveshaft all matter.. U-joints can only function properly with things correct.
Auburn, Washington
Confirmed, 4” lift squarebody, OE driveshaft length is fine. Possibly save for some extreme articulation.
I’ve got 5” front lift now and the front spline engagement is slightly suspect. 6” lift, a spacer or preferably longer front driveshaft is necessary.
Abbottgod
