- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
So I have learned some interesting things from a ford(haha) but also GM transmission engineer(former, rather) and when it came to my f150, the transmission cooler goes on the passenger side, where the cap is aswell, and he convincingly dispelled the idea the trans needs to run into the radiator during winter because that side remains much colder, almost ambient, and in winter conditions, the trans "cooler" will just remain being a "cooler" and having an auxillary cooler in front of the rad with a cover will achieve the same "cooling" as the in-tank trans cooler most stock vehicles have.
However, Its still kinda blowing my mind I guess and I guess it then demands asking which side the trans cooler is on any given application and then asking if that is indeed the cold side of the radiator(I assume the cap is always on that side, but hell if I know)
Im gonna go out on a limb and guess that the lower radiator hose in a cross flow radiator is where the "cold" side is.
Anyway, If this happens to be true, that means bypassing a radiator end tank shouldnt be harmful, however, it must be noted that liquid to liquid heat transfer is still more efficient than doing a small aftermarket radiator in front of your condensor/radiator but if you size it right, it shouldnt matter.
This may also explain why when I replaced the 2001 mercury grand marquis radiator I stabbed with a screwdriver long ago that ford didnt even use the end tank, but rather a small rad mounted inbetween the condensor and radiator.
I dont have an automatic transmission in my square but curious if anyones ever tried or has thoughts on this.
