Bronze Knight
USA VA
Robert
Put in my nice full sweep gauge cluster only to find out that the gas gauge doesnt work.... so i put led bulbs in the other gauges i took out and put it back together.
NICE! Where is that from?
78C10BigTen
pennsylvannia
C10 BIG TEN
Was that a factory squarebody option? Had to of been 89-91 only if it was. I thought you swapped it from something else.
No i didnt realize i forgot to clarify. Its my 91 s10. (Mini square) they are factory gauges
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Had a new home built for Ole Bessie. Only thing left on the to do list is order a 2 post lift
Sent from my moto g power using Tapatalk
That's nice! I'm jealous.
Doppleganger
OH-MI: Just like it sounds
I am sooooo jealous.
82sbshortbed
Fuckemall!!
SE Texas
Doug
I'm really happy this went easier than I thought, getting the fan shroud to fit. It's not perfect but, it in there tight and should not move.
Have to put something on top to close the gap.
Cut the corners up top and got the brackets to hold it on.
New water pump is in too. Just need to put a new hose on from intake to pump.
Got dark so I was done for the night.
Doppleganger
Doesn't look like much but I'm hysterical that it is at least beginning to resemble a truck again.
Dolly out - front wheels on. Going to have to take that front bar off and re-adjust the tie rod ends. Right side is in as far as it will go - left side has threads showing. Its close but the wheels still have a touch of that Marty Feldman eyes look from straight on.
Would have had the rear brakes and wheels on but as expected, the fk-ups at FedEx lost the 3rd package in a row. Would be nice if Rock didn't wrap the boxes in tape that advertises just what the filth that work at FedEx will be stealing. Figured they were the best of the 3 (UPS, USPS), but seems it doesn't matter - they're all run and operated by woke 3rd world parasites.
Bronze Knight
USA VA
Robert
Got most of the interior lighting wires run last night. 3 door switches are in and the cargo lamp is installed and working (though only if the interior lights are on).
Just got the front passenger door switch to run. I think I’m going to have to drill a hole into the A pillar though. I see a cutout in the dashboard but unlike on the drivers side it doesn’t go through.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Very, very nice!!! BUT...... I see no kegerator or poker table!!! Lol:smoke2:
Poppy 87
Bloomingdale GA
R10 Silverado
If you look closer, you will notice the fan I placed to enhance the dry time of the floor coating I put down. Have no worry's, beer fridge already has a designated spot!
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
Hell. Yes!
Mocked up the grille, bezels, bumper and bull bar after the completion of the radiator/rad support. What do we think?
My brother had restored the grille from the Suburban and painted the middle line silver to kind of go for a '76 grille kind of look.
Doppleganger
Hell. Yes!
Your brother did a really nice job. What a difference!
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
Later pulled in my '80 to solve my brake issue, repair diff pinion seal and transmission rear seal AND even my speedo gear finally! Right into the rear brakes (in which i have yet to pull since ownership) the passenger side wheel cylinder is leaking, and on the driver side the wheel cylinder rod wasn't in place and the cylinder piston was froze up! I'll have good brakes now! (I've almost died quite a few times)
Obullard74
