Snoots
Roger
Jimmy Sierra
Scraped more paint off the box side, mostly without the heat. It came off pretty easily except the areas that are still yellow. Gonna hit those with the heat gun tomorrow when the metal is a little colder to see if it lifts easier. This is a huge time saver. I’ll probably attack the fenders soon while the temps are cooler. It feels good when things go easier and making good progress.
Was that orange from the factory? If so, what is the paint code please!
Threw yet another o2 sensor in the truck (3rd one in 3mo) since I can’t seem to get a decent one. Found a GM one from Detroit so hopefully this does the trick. Also replaced those hideous blue Taylor wires that didn’t fit right (and were arcing on things) with another set of Speed Engineerings so I could use my boots again. Last minute maintenance before the roadtrip to Bowling Green
Rumbledawg
the back 40
K30 crewcab
nothin major, some door locks and map pockets.
interior of my crew used to be saddle and green, then i turned it into black and green few yrs ago.
didn't want to put the saddle map pockets back in so i threw a piece of diamond plate over the holes.
digging thru the garage the other day i found the old pockets, so my wife dyed them with some synthetic stuff. i think she did a decent job of them
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Mocked up the led strip light. It's got double sided tape on it but I also got metal clips too. I haven't stuck it on with the tape yet. Just put the clips on it .this weekend I'll probably glue it on when I stick it. That way it won't come off at all. I think the clips hold it good but I want them as a back up if the glue let's loose.
YM E-Bright Led Hood Light Strip... https://www.amazon.com/dp/B0BPYHCF9J/
30 Pack Black Metal Retainer... https://www.amazon.com/dp/B07WY56K6M/
I think it looks good and puts off more light that I thought it would. I hooked it up to the halos on the headlights so they all come on at once I put on the parking lights.
The photos are just with the halos on but it's hard to tell.
It fits perfectly on the plastic piece under the bumper. I'm very pleased with the outcome.
Anybody recommend a good glue that would hold up to rain and wind?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
No great milestone for most folks but the last couple of months have been great for me, I’ve been driving the Blazer a bunch and entered it in a couple of car shows for sheets & giggles. I’m really enjoying it.
As soon as I can get tires and new wood on my trailer I’ll drag it somewhere to play.
Oh man, thats exactly what i want to do to my blazer, that looks great.
Ken B
indiana
ken
Went thru and reconnected and tested all front and rear lights. found a parking light(bumper mounted) had been leaking for years apparently , new socket on order it was corroded away. but got lights on all four corners....made a list of to do's on my white board.....start knockin em out as time allows.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Was looking around under the truck to verify that I have a 700R4 trans. and doing a little clean up of the typical slight oil leakage. Also wanted to see If I could ID my rear axle and find transfer case tags. Everything is a little too gunky so I decided I would clean things up a bit. Picked up some Super Clean and Chemical Guys "Bare Bones". While looking as closely as I was(closer than I normally care to be, as I don't like finding the bad)
I also decided I needed to get the steering stabilizer replaced. NAPA had
Rancho to match the shocks as the PO had done. I am hoping to notice a slight difference in the steering slack(?)
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I said ^^^^^^
To clarify, I replaced all the old Rancho shocks not too long ago. Some of you might remember the post.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Sprayed wd40 on the crank windows crank and rollers because it was really hard to crank and stripped a handle. Drivers side is much better now with new handle and lubed. Passenger side is harder but able to get it down now. Before it was nearly impossible to roll it down. Lol
Rumbledawg
the back 40
K30 crewcab
i hear ya.
nuthin' but probs with chineseum parts
spent a few days surfing the web last yr looking for a map sensor and a fuel pump relay .
came across some old, old stock, but despite the yrs, they work perfectly.
this must have been in the parts dept a long time. Ed Morse chev is Jim Ellis chev now
82sbshortbed
Fuckemall!!
SE Texas
Doug
First ride with both windows down. Nice breeze today. Took him to home depot and heb after that. Nice weather today.
guillermoariast
