hoagster
California
K10, 1500
5.3l
Ok for those wondering, the defrost vents from a 81 and above will fit in a older dash pad!! The run about $16.50 apiece. And you can save some cash by having your old metal shell re-upholstered. Vents install just had to clean up the slots and carefully file the 4 corners round.
Finally got the driver’s seat mounted enough to take it for a ride at lunch. Feels good overall, I think I’m gonna redrill the floor bracket to move it 1” further toward the console, I’m about 1” offset from centered up on the wheel toward the door. Feels good though
chevytech87
Tomball, TX
Brandon
GMC R1500
Got my driveshaft rebuilt and started putting the new rear end together. Hopefully will be cruising with my new transmission and a 3.73 truetrac by Saturday!
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
What is a trutrac do? Like posi loc?
Camar068
Kentucky
10 yrs Air Force
what vehicle is that tach from?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I have a Trutrac 8.5 10 bolt 3.73 posi rear end in mine. Your gonna love it! I do.
I have 500 miles on my swap, working the kinks out. Picked up a free canopy to refurbish, installed a few interior mods including the stereo, floor shifter, cupholders & ashtray switch panel. It's coming along nicely!
Looks good! I see a 4x4 button, did you use a pushbutton transfer case?
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Working on more paint removal on the white truck today. Going to paint back of cab and bed so I can set it back on then do the rest.
87gmcburb
Don
GMC Sierra Classic Suburban
Finished up the power steering today, and put a timing mark cover on the harmonic balancer. Fired it up to bleed the system and played some Hot For Teacher through the exhaust for the neighbors.
I see you are using the edelbrock AVS, I just converted my 87 TBI to carb and using the same setup with an edelbroock air gap manifold. Which of the 2 front small vacuum ports did you use for your dist. vacuum advance? Did you use one for the charcoal canister as well? I see your 3/8 port in front is capped, are you running a pcv valve?
Lastly, when you first set it up and closed the air fuel mixture screws, how many turns did you open them back up?
SquareInheretance
