- Apr 11, 2017
- kansas
- Rick
- c20
Absolutely, timing first then carb adjustments. When dialing in performance it's ignition first then carbureation. Carbureator are so over blamed for incorrect timing or curve. Have messed with the timing shortly before your problem?Would the timing have anything to do with the idle? i know when I add throttle just a bit it smooths out so that's why I thought it was the carb, but could it simply be timing?
