- May 18, 2020
- Washington
- Todd
- K20
@RustyPile I’ll have to disagree on the weight thing. In your example anyways. The baseline difference between a C10 and C20 long beds is like 400 lbs.it runs pretty well and as far as i can tell its in good condition
This begs to be discussed, but no one has posted a comment along those lines.. The following is only my opinion but should be considered...
One word: WEIGHT.. Personally, I would never consider a 3/4 ton when designing/building a performance vehicle. They're just too heavy. A 1/2 pickup is considerably lighter and will outperform (acceleration, mpg, and comfort) a similarly equipped, and geared, 3/4 ton, simply because it is lighter in weight.. And the routine maintenance items -- brakes, tires, suspension and steering components are more expensive to replace on a 3/4 ton.
Quinn, this is totally your decision, but is it possible for you to retain the 3/4 ton for daily driving. Maintain it properly for dependability.. Locate and purchase a suitable 1/2 ton short bed and build it to your goals.. Trust me.. If you stick to a single vehicle, there will be times in its construction where it will be disabled while you're working on it.. There will always be situations where the particular project can't be completed on days off or in a weekend. You'll find yourself afoot, looking for a ride until that particular project is completed - and there will be plenty of these situations....
That’s not much. <10%. He’s not bracket racing. He’s a 16yo kid with an old pickup truck and a 16yo budget.
Or at least, weight is about the least significant part of the equation in this young man’s scenario.
The overall condition of the truck is primary.
Gearing second, and everything else from there is $/mpg or $/smile.
