Want to build a good horsepower, good fuel economy engine for a 1978 c20 with stock 350. I don't know much and need help.
Quinn_Hanifan
Toledo Ohio
Quinn
the top one, i tried your pencil trick and it worked for a bit but the engine still died when I left it to idle like It does normally
The top one are the secondary air doors and are not supposed to open when you step on it only when the engine is drawing sufficient cfm. The choke is the lower one and it is open.
Quinn_Hanifan
Toledo Ohio
Quinn
Ah okay
How far have you driven this truck at one time. Has it ever seen 30 minutes continuous use?
Quinn_Hanifan
Toledo Ohio
Quinn
most certainly, the first drive home was over an hour, and when it was running better I've driven decently far, or for at least a while.
K, so it doesn't get hot in 30 minutes of driving,that's a good sign.
Quinn_Hanifan
Toledo Ohio
Quinn
The temp gauge has always stayed under half, mostly staying at a quarter when driving for a while
How did your current problem start?
Quinn_Hanifan
Toledo Ohio
Quinn
well thats what im trying to figure out, I'm not quite sure. I'm just trouble shooting at this point.
Trouble shooting? Check compression,check vacuum reading, pressure test the cooling system or at least try to find an external coolant leak and read your old plugs.Look hard for vacuum leaks,lines off etc. Pull and plug the inlet hose at the fuel pump see if it runs good for a minute,locate the carbureator vent fill the carb through the vent with a mustard bottle, dish soap bottle full of gas see ifvit runs good for 30 seconds that way.
CountKrunk
ATL
Count
C20 Custom Deluxe 3+3
v8 350
How can you tell it's drinking coolant? You've been keeping an eye on the expansion tank?
Have you ever changed the oil? What does the oil look like?
Quinn_Hanifan
Toledo Ohio
Quinn
i have done all fluid changes and filter changes, including a coolant flush. oil got pretty dirty fast but I just added a couple of quarts because it was concerningly low. the expansion tank is what I noticed, it was pretty much empty even though I added more coolant to the proper level and such only a couple of weeks ago. no leaks or dripping fluids from anywhere that I know of.
Quinn_Hanifan
Toledo Ohio
Quinn
Would the timing have anything to do with the idle? i know when I add throttle just a bit it smooths out so that's why I thought it was the carb, but could it simply be timing?
Pugs Speed Shop
