- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I do the same thing. As for gaskets that is what I thought, although I may buy a gasket and seal kit to be sure if I tear anything.
I know the parts/guts I am going to use are good, they are in my 88 and we drive it alot, but the case around the PS cover for the 1-2 accumulator the back end if broke off and leaked. I used some seal all glue on it and seems to have done the truck.
If it starts to leak or I just have the time and want something to do I am going to switch cases, the case is good, came from dad's 84 but the internals suck. it was acting like driving with the brakes on, not really slipping like in neutral just acting like it was loading the motor and revving but not transferring the power. So it's a donor parts trans now.
Another point I was going to make, that musty be the stage one shift kit/HD version since it has 2 check balls left in place. I've put in 2 of those kits and did the stage 2 street/strip version both times, uses the same stacked plate setup but only one check ball. The stage one involves removing the spring from the 1-2 acc. on the side cover too. I never did that one.
This one didn't have the accumulator spring either for some reason, but yes, its the Stage 1 RV/Heavy Duty Kit. I have done many Stage 2 Kits, and I love the way they work on the T350. I had a guy once, punch me out 100 of those transfer plates. It was like $100 set up fee, then after that, it was like $1.25 per plate. So I had about $2.25 in each plate, threw away check balls and srprings, and then used a paper hole punch to enlarge 3 or 4 holes in the stock paper valve body gaskets and there I had it. It was a HRPC Shift Kit. I charged the same price as store cost as a B&M shift kit back then. Those were the days, I was making some cash back then.
