- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Also, remove the 3 pressure tap plugs. This is not always necessary, but a good idea so that you can run some air thru the tap ports in the event some debris has been trapped in the ports. These ports are only used for transmssion testing and diagnotics.
This is what the pressure tap plugs look like out of the case.
Here is what this side of the case looks like with pressure taps and accumulator removed. This case is now 100% stripped and ready for cleaning and rebuilding at this point.
