Front Brakes Grabbing
Mango
JacksonWyoming
Gil
Hey All
Front brake are grabbing, at first few stopps gets better when they warm up ?
This just started to happen on my 89 Burb replaced brake calipers, Rotors, and pads about two years ago Drive about 125 miles a week
I did do a complete brake fluid flush at the same time
Any suggestions ?
Thanks All
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Hey All
Any suggestions ?
Thanks All
Some of it could be the lining material and composition. My Burb does that especially when it's cold.
When you replaced the pads and calipers, did you clean and lubricate the mounting surfaces and the pins/bolts? With high temperature brake lubricant? Many people forget these important steps.
Mango
JacksonWyoming
Gil
Thank You Yes I did, Permatex Ultra Brake Pars Lubricant
Is it grabbing in one direction or the other? Or are the brakes just "grabby" when cold?
dhartman
michigan
daniel
c15
How are you Rubber Hoses? When colder temps they can tend to contract. as the system heats the line will sometimes open and flow better. Just food for thought. :33:
fast 99
Spokane, Washington
All the previous suggestions are correct. If the brakes are otherwise decent after the initial few stops, suspect pads. Have seen that happen with rear drum brakes locking up cold especially in damp conditions. Try a different, preferably name brand pad.
For diagnostic confirmation make sure the rear brakes are working by carefully road testing [low speed] on a dirt road with panic stop or using a heat gun on rear drums after several hard stops.
Mango
JacksonWyoming
Gil
Thanks All Rear brakes have no adjustment hole, Should defenatly check those and replace shoes how would i know if i should change the drums?
Front brake Hoses New. Was good before in cold temps?
Not Grabbing Left or Right Perfectly centered
cartunesguy
