- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
I'm sure this is fixed but it seemed like a good place to throw this in so you all can put in your memory in case you ever need it.
@Grit dog was talking about redneck helicopter coils,I'm going to tell you how I make redneck helicoils. I prefer to just buy and use heli coils but being an hour an hour away from everything it's not always possible,and sometimes you have to order the kit you need. Here's how I do it find a bigger bolt that I have a tap for clamp a chunk of 2x4 in the drill vice bore a hole your new bolt will fit snug in.Don"t move your wood or the drill vice,put your bolt in the hole,put a combination wrench on it, use the drill size for what ever bolt you stripped outs tap size to drill a pilot he in the bolt. Now you have a bigger bolt with a hole centered.Use the hollow bolts hex head and screw it into your retapped bolt hole. Keep your wrench on it and tap the I.D. to the size you need then drill or grind the head off. I know Pita but if you have to wait a day for a heli coil you do what you have to.
Damn that's a slick trick there.
