steering column or shaft
curse
49002 portage mi
kyle
Can anyone hook me up with a steering column that has the double D end for the steering shaft (2 flat spots and center bolt) ...tilt or non-tilt...no headlight dimmer...and no wiper switch.
Or a steering shaft with the splined end and rag joint end.
My steering column and shaft were replaced with newer parts and the column is pretty bad. I have another column with splined end but am having a hell of a time finding the correct shaft. I also have an xj shaft but i'd need a column with the double D end. So one or the other.
I'm in Portage Mi and can take a drive if it's close enough or i'd need someone willing to ship to 49002.
Thanks in advance, Kyle.
can you get a pic for refence? I have a couple of column shafts
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Replacing the inside of ours this week. Got host from junk yard on internet. It was spline and we have the bold so swapping inside shaft for the new 1976 column no cruise/ dimmer which is what it had when we got it. Ill let you know if its usable.
Randy and Easton
sszcam
