shift indicator
JohnRod
Kingman,AZ
Rod
2500 Suburban
can you buy a new needle with wire & clip? if so where. my square is a 1976 C-20 Sub.
thanks Rod in AZ
germando
dfw texas
Justin
c1500
I got mine from lmc like 30 bucks and works great
G
Don-T
Vermont
Don
I bought mine from LMC as well. Works fine.
75gmck25
Northern Virginia
Bruce
It’s also common that the little plastic piece the wire slides on may have broken. It’s molded as part of the plastic cluster housing, so you have to replace the housing to fix it properly. Not real expensive from LMC, but it requires quite a bit of time to pull the cluster and swap everything over to the new housing.
630erik1
