WFarm
- Jan 11, 2023
- Central Virginia
- Paul
- R1500
- 350 tbi
My shift position indicator is off and needs adjusting to point at the selected position. It seems the adjustment would consist of removing the clip that secures the shift position indicator cable from the column and then reattaching it to get everything lined up properly. Am I correct? Can you remove and reinstall the clips without damaging them and needing to replace them?
