Rust Options
No
No
No
No
No
No.
Conventional Por15 is a coating that prevents future rust. They also make a converter they call "Rust Dissolve" which is the equivalent of what you already used. The Por 15 Rust Preventative would not be redundant.
Richmond, VA
Andrew
R10
Awesome! Thank you midnight! I am very pleased with how the sheet metal looks on this truck. It's remarkable. The stuff I applied thus far was super easy to apply and seems to be of high quality.
I wouldn't put por 15 over a different coating,not how it was designed to work. It is designed to be used over phosphoric acid prepped metal. Part of a 3 step process ( water based cleaner) marine clean ( phosphoric acid etch) metal ready prep ( top coat ) Por 15. I use a similiar 3 step process lots of people have for decades. Mine step 1 simple green or purple power cleaner. Ospho phosphoric etch. Top coat depends on where I'm using it and for what reason. POR 15 over a different coating maybe would be fine,but the price and work involved I'd use, POR15 by the book or whatever your previous coating manufacturer recommends.
cbengston
