- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
The larger modulus number means the frame has either a larger frame shape or more material in the frame since it is completely independent of the material used... not that it is harder or made of a different material. Notice that right above the circled modulus numbers it lists the material, which is the same carbon steel for all frames. Based on the 36,000-39,000 psi number quoted, I would guess they used A36 steel which is a mild steel that has 36,000 psi yield strength. If you have the frame modulus and the yield strength of the material, you are able to calculate almost all of the important load limits of a frame.You are certainly helpful @AuroraGirl.You have a eye for details.My hard drive isn’t full by no means,but it’s full of work data,mostly.I can remember quite a bit of driveline and axle info.
