RETRO-Mod: Jeep intermediate steering shaft
SquareRoot
I'm twenty seven pages deep into this thread trying to figure out the purpose.
Correct me if I'm wrong, but all this mod does is eliminates/reduces the slack in the steering by replacing easily wearing out "rag joint" with a Jeep shaft that has some integrated rubber dampener integrated in the steering wheel end?
I took for granted that these trucks have "approximate direction selector" instead of the steering wheel, do you say that these trucks can have sharp handling?
Is the dampener necessary? I can see how soft is the rubber in my rag joint, it easily "bottoms out", what would happen if it was replaced by something solid like a U joint?
Replacing it with a u joint is exactly what the jeep shaft does. Carry on.
Camar068
10 yrs Air Force
These aren't the rag joints we're looking for....move along....move along.
mibars
Nadarzyn, Poland
Michal
Suburban V1500
mibars
Nadarzyn, Poland
Michal
Suburban V1500
Did the mod, ended up buying a different one than linked above. Steering is so much more precise now!
Some notes:
-These plastic inserts holding both halves together are most likely PTFE/Teflon. It emits highly toxic fumes when heated. Do it outside and mind the wind direction.
-After removing those inserts you may end up with little bit of slop between parts, as I did. A one good hammer smack on the tube part to close it a little was enough to remove it.
-You don't need to remove both nuts holding steering shaft from a firewall, you can leave the one under brake booster and just spread the bracket a bit.
SquareRoot
I drilled a 3/8 hole thru one side of the outer sleeve then welded a 5/16 nut over the hole. Assemble shafts and screw in a 5/16 x 1 inch bolt with a jam nut. Tighten just enough to eliminate the slop. Never had to mess with it since.
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
whats the difference in later jeeps? 97 and up?
edit: called borgeson. The earlier is 1" DD and the later is splined.
ksquare84
