- Sep 29, 2010
- Green Bastard Parts Unknown
- Jay
- pontiac aztek
Difficulty = 1 (1-10, 10/hardest)
What you will need:
Delay wiper switch and module
No 2 phillips screwdriver
8mm or 5/16 socket or nut driver
About 20 minutes
First thing is getting a switch and module, you may get lucky and find one in a truck already or you may have to resort to ebay as i see them NOS or used once in awhile or I believe LMC carries the switch but not the module. Later modules WILL NOT work. You might look in a GM made before 1984 like a Cadillac or Buick for a module that may work. I can't guarantee that it will be the same. Here is a pic of the truck module.
To get it out, take the phillips screwdriver and remove the 4 screws holding the bottom trim plate under the steering column.
Then remove the 8 phillips screws holding the cluster bezel on and carefully remove it. You may want to put on the e-brake and put the truck in first gear for get around the column shifter.
Then take your 5/16s (or 8mm) socket or nutdriver and remove the two screws holding the wiper switch in.
It is completely plug and play. Let me know if other years are different, i got this from a 1981 truck and put it in a 1981 truck.
Test switch in your truck to make sure it's working and installation is the reverse of removal. And now you have intermittent wipers in your square.
What you will need:
About 20 minutes
