BRetty
- Jul 16, 2020
- Los Angeles
- Franklin
- c10
All,
I am replacing a ruptured hose on my '73 C10, and I have a few questions about the process.
My square: '73 C10, 350 smb, longbed, lowered 4.5/6, dashboard and steering column (and other parts?) from '81 Suburban, many things not done, or done poorly, or never finished, by PO.
______ THE BACKGROUND ________
My brakes went out two weeks ago. I had noticed some warning signs the day or two before: twice brake pedal was suddenly stiff with no travel, once (right before I got to work) pedal coasted down to the floor. Heading home that eve, I checked brakes in parking lot, drive-STOP!, drive-slow brake, drive-STOP!, it seemed to be holding pressure. I planned to park it at (near) home, leave it there, and take it in to mechanic on corner first day off.
HA! I got one mile and failure began, more travel on pedal, then suddenly pedal hit the floor and would not return, I rolled through a red light while frantically grabbing for the pedal with my hand. AAargh.
Opening the hood, I had extremely low fluid. A friend gave me a ride to AutoStore for more brake fluid.
The seal/gasket was not sealed -- in the rear section, one corner was loose and sucked down into the well. Hmmm.
I topped the reservior up, and after a few false starts with not capping the reservior right, I had enough brake pressure to try getting home.
Brakes were OK for the few miles home, but just as I turned into my neighborhood pedal went to floor again. I engine braked and got her stopped (I have no parking brake, repairing that is a separate post). I was slammed at work (also a separate post) so when parking enforcement was due to come 'round, I paid to have her towed to work, where it is flat and I am off the street and we have blocks and jacks and buckets and tools.
___________________
So in in daylight on flat ground, I started looking where I was noticing a leak that had just started -- I noticed it when I was towed and the two days parked at shop. Rear differential
I can crawl under the back of my truck without jacks, so I crawled in and saw this:
The Arrow saying BUSTED! is where the hose is cracked, dripping fluid and generally defeating all hopes of pressurization. So I have ordered that hose and will replace it then move on from there I checked all the other connections and lines and didn't see any other signs of major leakage, so I hope this fixes it enough to get it in to the shop.
Some questions about the procedure:
-- The hose I ordered comes with an integral Tee-junction. I will dig out the old tee-joint from its crust of congealed brake fluid on top of the diff. Is there anything to know about removing and re-inseting the hydraulic fittings rom the old Tee into the new? I assume the lines run to the wheels are double-flare ends that will seat into the new fitting just by wrenching. ?
-- I also assume that the hard brake line to the new hose, through the bracket, is a straightforward line wrench procedure? Is the connection securing to the bracket a separate nut/fitting that is integral to one of the lines?
-- The exhaust on this truck is a hack job, and I need to replace it all before another muffler just falls off, but FOR NOW, should I worry about the connection being that close to the exhaust pipe?
-- I will need to bleed the brakes after all this. Is $50 for a HFreight vacuum bleed kit a good investment since I will be doing this myself?
-- Is removing the radiator fan and fan shroud simple enough, or are there pitfalls? I need to get better accedd to the prop valve so I can make sure things are kosher while bleeding the brakes.
___________
Thos are my questions for now. I appreciate any advice offered before I tackle this on Tuesday. My car buddy is Deep in the Heart of the Great State of Texas at his grandfather's 100th birthday, so his phone availabality is limited right now. GMSB is my other, other lifeline.
THanks in Advance,
BRetty
IMPORTANT -- My BRAKE warning light had been on since I bought the truck. It was the proportioning valve wire. I redid the electrical this summer but was so focused on electrical problems that I never considered it might be a real warning indicating prop valve was stuck in fail mode. I had not noticed brake problems but in retrospect I was getting quite a lot of brake dust on my front wheels. MIGHT BE IMPORTANT.
INTERESTING -- Looking in my parts manual, my master cylinder and reservior doesn't look like anything I see in there. Mostly the cover is flat, not domed, and there is no retaining clip on the top. I don't have a pic to include right now but I will...
___________________
___________
THanks in Advance,
BRetty
