- Sep 29, 2010
- Green Bastard Parts Unknown
- Jay
- pontiac aztek
Well, they were optional in vans too...so check those vans as well!
How hard would it be then to go the 47RH Dodge trans? Obviously it will bolt up to the motor. But what about shift linkage and Tcase? Dodge used the same Tcases with same passenger side drop Tcases? The 47RH is non electronic other than the TCC lockup and the Overdrive Unit can be enabled or disapbled by a push button switch.
http://www.allpar.com/mopar/transmissions/47RH.html
Oh, and I'd imagine is still uses VSS since Speedo's were electronic by then right??? So then he'd need to get a VSS capable Tcase. I think NP241C is where those start.
The problem would be he would need to get the dodge adapter for the cummins. i thought Dodge was using DS Drop transfer cases too?
Hell, I don't even know if Dodge changed like GM did. But I was certain, Dodge is PS drop and Ford was DS drop. You mean that 47RH doesn't already have the Cummins Bell Housing? I'm thinking it should, it whats comes in the Dodge 2500 and 3500 trucks with the Cummins originally, and why I suggested it. It obviously should be strong enough if that's what Dodge uses OEM. It was just a thought. Thinking about this though is making my head hurt. Being sick and taking meds my thinking is jacked up the last few days.
Could he use the tailshaft and housing from a 241C in a stronger case?
Though the 241C was used behind the diesel and turbo diesel 4x4....
Yeah, the 241 is supposed to be slightly stronger than the 208... and a direct replacement to boot. I may be wrong, but I think Dodge went DS drop with the new trucks in '94. I have no idea if the Dodge T-cases have the same mounting pattern and input spline count as GM. I doubt it though.
