Redfish
- Nov 6, 2021
- Prairieville, LA
- Andrew
- V1500
Well of course they should... but will they? I had some trouble getting one locally and then they didn't last so I decided to order from RockAuto. That solved my oil pressure gauge problems.So here is a snapshot of my current one from the top. I understand there are 60 and 80 psi versions. If I ask for a year specific one at an autoparts store they should pull up the correct one right?
Regarding the oil pressure SWITCH that is against the firewall; it is difficult but not impossible to access. In my ignorance I broke the brass piping that fed it and had to piece together some hardware store components. I had to remove the distributor cap to access it more easily. I actually had to use an EZ-Out to get the threads out of the engine, it was difficult to reach but not impossible. That switch is a backup to the Fuel Pump Relay. That is all it does.
The sending unit/sensor for the gauge is not difficult to access if your truck is 4wd. Crawling underneath is the worst part.
