JamesSam
- Feb 15, 2023
- VA
- Sam
- Silverado V10
- 5.7 L 350 v8
I know tons of discussions already exist about the oil pressure gauge and sending unit. I have already searched the existing forums that helped me to trouble shoot but I'm hoping to get more info with some details in my trials. Here goes:
1987 TBI 350 4WD
When I bought my truck several months ago the pressure gauge reacted to driving and was at a seemingly healthy range between 35-55 PSI and eventually dropped down to around 24-27 PSI and wouldn't really move much at all. I then started checking my oil often and have really only needed to add a quart once. Then I started researching and thinking my sending unit could be bad, or there was a kink in the hose, or a ground wire...most of you all know by now. I crawled under the truck after locating the sender and sending unit to see if I could find a kink in the hose that leads out or obvious damage to wires or leaks etc.. I didn't notice anything that looked out of place but I did move wires slitly and the hose to ohysically see if there was anything not immediately obvious. I left it thinking about what to do next. About an hour later while driving around I looked at the oil pressure gauge and it was on 0. Having never seen this I was immediately alarmed but the truck was running fine so I figured it had something to do with me messing around earlier. When I got home I let the truck cool down a while, unclipped the wire from the sender then turned the ignition to on, but not cranked, to see if it was the sender unit and somehow the oil pressure returned to where it was at 24-27 with the wire unclipped! I cranked the truck and the gauge actually moved the needle ever so slightly. I turned the truck off clipped the wire back in and cranked it up again to see if there would be an adverse reaction(?) but the pressure auge remained reading the low pressure. I revved it a few times just to see if it would move the needle and it did. Happy as I could be that the gauge actually shows there is oil pressure I turned the truck off and decided I would call it a win.
Anyone please respond with conclusions or best guesses!! Any insight will be greatly appreciated.
-Sam
1987 TBI 350 4WD
-Sam
