- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
So, long story short, my son's truck had a 20 year old Chinese clutch in it when we bought it from our neighbor. It started having disengagement issues after driving a couple thousand miles. Upon removal, everything still looked new. After installing the new Napa clutch set, disengagement was good and the trans shifted beautifully. Now here we are, maybe 4000 miles later, the clutch is having disengagement issues again. Also, the clutch pedal gets stiff towards the bottom of travel, which was a symptom last time as well.
I'm guessing it's a pressure plate issue, again. Has anyone else had similar troubles lately? Has anyone had good luck with any particular higher end (but still affordable) clutch kit for a similar application? I don't want to keep doing clutch jobs if all the stock replacement stuff is garbage now.
