Disco
- Feb 13, 2022
- Texarkana, TX
- Mike
- C10 "Big 10"
- 350 4-bolt
With the clutch all the way to the floor and the adjuster rod on the fork nearly all the way out, the trans scratches 1st (low?) and reverse. Nothing I do seems to fix it. There seems to be plenty of spring tension on the fork, and it doesn’t have much play. What am I doing wrong?
The shop manual recommends trimming the rubber pedal stop under the dash to 3/8”, but I can barely find that with probing fingers, much less see it or figure out how to remove it to perform said modification.
