Mysterious wires/plugs in engine compartment
k30Dually
Fl
Real quick not sure what wires/plugs these are inside engine compartment. Fairly long maybe to engine mounted accessories?
1983 K30 sbc forgot colors each wire but here's a couple pics...one on far left has 4wire flat plug wich is burnt
75gmck25
Northern Virginia
Bruce
Does the truck have a auxiliary battery tray on the drivers side? With a 2nd battery it would have a relay on the driver’s side fender well to control the charging. It isolates the 2nd battery when the ignition is off, and the middle plug looks like the right type for the original relay.
Finkaire
Finkaire
California
Loren
Silverado c10
Top plug looks like it may be the A/C clutch wire?
3dbello
