gmbellew
- May 27, 2018
- Kansas city
- glen
- suburban 1500
I had previously had issues with the delay wipers on the 1990 suburban. The pulse module and switch were replaced, but were not the culprit. it was the motor that needed to be replaced. Likely the onboard circuit break was getting weak or the park switch bad. All was good for 6 months or so.
Now I have an issue where sporadically the intermittent doesn't behave properly and/or the washer pump doesn't work (or start the low speed wiper for 6 sec).
once when the washer pump/6 sec low speed wasn't working, I was able to check for power and ground at the pump. I had constant power, but no ground at the pump with the switch pressed. then I swapped the pulse board, but the pump/6sec low speed still didn't work.
sometimes it all works, sometimes the delay goes funky, sometimes the washer pump/6sec low doesn't work, and sometimes they both don't work. It seems random. today it is the delay issue only, for those that are interested.
the only place these two circuits share anything is 1) at the pulse board, 2) at the switch and 3) at the common ground leaving the pulse module.
the pulse board seems OK, it was swapped with a good one and no change.
if the common ground leaving the pulse board was bad was bad, it seems that I would have no wipers. also, I can look up and see the ground bus bar and it looks clean and tidy up there.
So that leaves just the switch (a new one is on order) that could be bad.
I wondered if anybody had any other thoughts, or had seen a similar issue, before I get the switch replaced when it comes in?
