Intake Manifold Install
Mango
JacksonWyoming
Gil
@Rusty Nail, Double Dingo
There is no place to use the Hood lined with insulation
I have a solution a Gallon of Gas and a Match
Walk to work its only eight miles one way
So lay a 2x4 across the hood opening tie your fuel lines to that. And I'm not slamming anyone here, but this would only pay 3hrs at the dealership, even if it was my first one and even if it took me 9hrs to do. If there was a leak afterwards, even if it was unrelated to the intake. I'd still have to find the leak for free, to prove it wasn't my fault. If there was a leak from using a budget gasket set from wherever, I'd have to do it again for free or if I was lucky warranty time. But Damn if everybody doesn't want to call the dealer tech a thief and the dealer parts,stealer parts. And just as an aside, when you can't fix it and your mechanic can't fix it the common response is you'll have to take it to the dealer. To the guy who has too much money wrapped up in his tools because if you can't pick your car up at lunch because of a broken tool. Its going to be WTF do your guys use fisher price tools?
Mango
JacksonWyoming
Gil
Well doing the Intake Man Gaskets Again tomorrow using Ultra Black RTV and moving the fuel lines completely out of the way!!!
What is the torque values for the Manifold Bolts?
I set them at 25 ft lbs, and it leaked from the back China Wall I think? Saw a video set at 35 Ft lbs, Other at 30 ft lbs
some at 50. ft lbs, Hanes Manuel says 25 ft lbs
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Mango
JacksonWyoming
Gil
Looks like the Distributors was over torqued, seal was crushed on one side? Did not pull the Manifold Re torqued the bolts to 30 one was super loose ground wire attachment
Now wait and see it that was it
Mango
JacksonWyoming
Gil
Well Well Still dripping Oil! Oil Pan seal? Rear Main Seal?
Intake Manifold Seal on the back side ?
Going to drop the Dye in and hopefully see the issues?
New issues Seems to idle high in park when engine up to temp IAC gone Bad ? was fine before
I wouldn't be randomly guessing parts went bad by coincidence while you were doing this. Idling high it's getting air somewhere so first thing is double check your work,check for vacuum leaks,intake leaks throttle body gasket. See if there's an IAC reset procedure.
3dbello
