- Apr 11, 2017
- kansas
- Rick
- c20
This isn't aimed at anyone so nobody take it personal. It's just good advice. So a post goes up. Getting bad milage, runs horrible I changed my carbureator twice,put on a FP regulator, 1st one leaked so installed another one, still runs bad, I replaced my cap,rotor,wires,now runs like crap,searched for vacuum leaks, pulled off all my smog equipment,still runs bad. Now let's jump to the end results. Well turns out the fuel level and fuel pressure were wrong on the carbureator, I found I crossed 2 plug wires and 1 cracked a plug insulator, deleting the egr and esc, caused detonation problems,on and on and on. Yeah finally figures out my distributor wasn't advancing. Now if this were a real situation,this guy did all kinds of extra work,spent lots of extra time and money,and created all kinds of new problems to diagnose,because he didn't diagnose in the first place. If you don't know how to diagnose,ask. Just because you threw a code that doesn't mean that part has failed,it is possibly a symptom of another problem. Replacing an O2 sensor that has a break in the car side of the harness doesn't fix anything. Putting a 5lb fuel pressure regulator on a car that only has 3 lbs of fuel pressure doesn't do anything,changing good plug wires,doesn't do anything. You'd sue your doctor for removing a healthy,arm,leg,lung,kidney,or your mechanic for changing a good ecm, transmission,or speed sensor, but you think nothing about doing it to your car.
