Dash Differences?
scape
Springfield, MO
Shannon
LS
I recently purchased an 85 GMC. I'm coming over from the 76-72 trucks, but grew up in Squares. The dash of this truck has the check engine light in the center between the mph/fuel gauges. I thought this was only an option for diesel trucks, but I guess not. I don't see this dash replacement option on LMC. Was this just a one year thing? Truck has a 350 in it and documentation matches. Sorry in advance if this is a dumb question.
scape
Springfield, MO
Shannon
LS
Here is a pic.
nvrenuf
Mobile, Al.
I've only seen that top center warning light on diesels, any chance yours was originally a diesel?
scape
Springfield, MO
Shannon
LS
No, it wasn't. As stated above it came with a 350 gas motor...but, like you I have only seen that in diesel trucks. Fairly certain she is an unmolested truck as I have all the paperwork from new with it.
TonyMann
Everett Wash.
Anthony
C10 Silverado S B
350CI
I have a 1980 Silverado, and it came from the factory with a diesel, it also had a glow plug indicator light where your check engine light is. If you have a ECM you will need to keep your check engine warning light, or you can do as i did when I switched to a gas 350, I changed the gauges bezel,and put one in from a 1981 non computer, non diesel Truck.
scape
Springfield, MO
Shannon
LS
This truck did not come from the factory with a diesel. It came with a 350 gas motor that is still in it. This is why I'm confused about the gauge cluster having this. There is no "glow-plug" light in the display. Check Engine and Battery Indicator are the only two lights.
scape
Springfield, MO
Shannon
LS
I guess it is possible. I'm surprised the lights work in it if that is the case but I sure don't see other trucks with that "option" unless they were diesels.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Maybe an "update" someone thought was cool. It certainly is a conversation piece due to its rarity.
85K304SPD
Las Cruces, NM
Richard
Cool. None of my '85s have that. I wonder what it is hooked up to, that makes it turn on. Maybe you will find out some day.
85K304SPD
Las Cruces, NM
Richard
Show us some pictures of the truck, please. What is the "Gold medal special" option?
Soundmound
North Central Washington
Dave
Scottsdale
My '84 factory 305 gas california smogger has the light in question. Truck is bone stock. The '85 plow rig I picked up does not have the light. It was a 305 from birth, but has been swapped with a '73-'80 400 small block.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Diesels had a two-light insert between the speedo and the fuel gauge. AFAIK they all had an amber "Wait" or "Glow Plugs" light on one side (depending on vintage) and a red "Water In Fuel" light on the other, which in trucks up to about 1986 would also be illuminated by excessive vacuum on the fuel filter.
Apparently the gas engine trucks had a "Check Engine" light on one side and some other light. If they don't say "Wait" or "Glow Plugs" / "Water In Fuel" it was not from a diesel. "Check Engine" would probably indicate a 305 ESC or a later TBI engine.
ksquare84
