mibars
- May 13, 2023
- Nadarzyn, Poland
- Michal
- Suburban V1500
- 350 TBI
My Cruise control is bit erratic. I've searched the forums and I couldn't find a thread that would describe similar issues.
My cruise control works, but starts to misbehave after couple of minutes of driving. First it works correctly then it starts to slowly lose speed, applying too little throttle. If I manually accelerate and bring it back to speed then it sometimes manages to take over and keep the speed for a minute or two. I can also feel that pedal is stiffer when cruise control is off.
If I keep driving with cruise control engaged but not doing it's work (manually pressing the gas pedal) and I start to lose speed uphill, I can feel that actuator takes over as the pedal gets softer and sinks under my foot a bit. Usually not enough to be able to bring the Burb back to target speed.
Couple of times the cruise control was keeping the speed correctly and then lost all the support, like it shut off, despite being on. Turning it off and on again makes it work again, however usually it won't be able to hold speed.
In any case when the cruise control starts to lose speed it does not react to "set" or "resume". It needs to be shut off and turned back on again.
Any idea how to troubleshoot that? On a 1st glance I can't see any specific issues under the hood.
