C10_Blackie
- Jan 2, 2024
- Seattle, WA
- Rob
- C10
Hi all. Sorry about the length of the post but I didn't take any time to take photos while this was happening. I have a 1981 C10 with what i think is a Goodwrench crate 350 motor of unknown age and origin. I'm not an experienced or knowledgeable mechanic. I bought the truck in December. I haven't been able to drive it much as I got COVID right after buying it and took me a while to recover, but I've taken it on three or four short trips so far in order to shake it out and get used to it.
While on a short trip today, I started to hear a clanging sound that started out faint but quickly got way worse and then stayed loud and constant. I pulled off the road, left the engine running, popped the hood and found that what I'm gong to call the alternator pivot bolt had worked itself out and was impacting the cooling fan. I shut off the engine and tried to screw it back in place thinking that it had just come loose but it became apparent that it had sheared off somewhere back in there. I didn't want to back it all the way out so I just pushed it back in place and limped the mile back home only having to stop and reset it once.
I pulled the alternator out when I got home since I had been hoping to find some engine stamp numbers back there (didn't, unfortunately) and found that the bolt had sheared off in the effing engine block. I noticed that the bolt goes through a bracket connected to the block, then through the alternator, then through a sleeve that is on a bracket attached to the alternator, and then into the the block. So I pulled the bracket off that was attached to the alternator and used a shorter bolt to just attach the alternator to just that one bracket and put everything back together. After a short half mile drive, the belt tension didn't seem to loosen and everything looks good still.
So first question is that I already had an appointment with a good shop about 25 miles away (mostly highway) next Monday to have the truck checked out. Is there any reason I shouldn't drive it there as-is if it looks like the belt tension is holding?
Secondly, what would make a bolt that size shear off like that? Is there some possible root cause that I should be concerned about, like maybe the motor is moving around too much relative to the fan pulley?
Thanks.
Thanks.
