Adapt 4x4 Th350 in Place of 700r4
Yeah I guess so huh? That would have been 81 for sure and some 82's that weren't 700r4 yet. But still, his output shaft wouldn't work having a NP203 unit.
Right. With the short output, you only options are the 203 and 205.
00-dirt
ohio
Dustin
k-10
So how much did you actually cut off of the output shaft?
Ahh Hell !!! Good Question. I should have given the measurements. I have another shaft here I cut off, but it's in storage at the moment, and if I can find it... I'll do some looking around. I may not be able to tell you how much I cut off, but at least tell you what length to cut it too. I'm wanting to say it was about an inch and that included saw curf. The blade is pretty wide on the chop saw like maybe an 1/8 inch.
00-dirt
ohio
Dustin
k-10
I will take what length to cut it to getting ready to make this swap. Thanks. also I am mating to a 208 does that make a difference besides needing the adapter piece?
This is to adapt to an NP208 so it will work fine. You'd use the same adapter that is used for the 700r4. This will also work for a NP241C.
All you're really doing is putting in the spacer which I assume you have already, then cutting down the 2wd output shaft so it's the correct length with the adapter. I still haven't made it to storage to see if that shaft is in there.
Krusty78
Oviedo
Aaron
K5 Blazer
My buddy has a 700r4 mated w/ a np208 from my research he needs the spacer for sure but whats the scoop on the output shaft can we just cut his stock one on the th350 and run the 700r4 driveshaft?
MrMarty51
Eastern Montana
Martin
Hey HR, seems some good things is coming Your way, for once.:console:
jth678
georgia
john
v10 custom deluxe
when making the 700r4 to th350 conversion what happens to the electrical plug on the 700r4 ? and what about speed sensors and such?
If you're talking in a 4x4, the Speedo is controlled by the Transfer case, so you'd use the same Tcase and the Speedo is not an issue.
For a 2wd, you'd need an adapter since no Th350 has provisions for the Electronic type since the Th350 output shafts don't have reluctor wheels.
jwendK5
Springfield, IL
Jake
ok folks im new this page and plan on swapping out my obviously hurt 700r4 (i know its hurt cause i abused it) for a th350. i found a reman transmission and all the help i need as far as gathering parts. the only thing i cant find that im confused on is: should i buy a th350 for 4x4 or 2wd? please help and sorry for the newbie question.
TIC
east Tennessee
K1500
350cid
i wish hotrod could have found that cut shaft and posted the lengh it woul save me a lot of grief.
TIC
east Tennessee
K1500
350cid
i think we came to the party to late, i just got two trannys one out of a 75 4wd, one out of a 84 pontiac. the 84 is a lockup converer. now someone in an early post said the 4wd bell houseing was much stronger, i have both sitting side by side, there is no diferance in the case's except one has the plug in for the lockup coverter. but its possible the one that came out of the 4wd is not original to the truck, i cant see gm making two differant housings the great thing about gm is keeping thing interchangable. no mater what 350 you use you got to change the out put shaft, either from the spacer kit or cut down from a car tranny. from what ive read everyone seems to shy away from the lockup tranny but after gutting both and laying out side by side, the 84 tranny looks to be much stouter, evey thing looks stronger, the band is twice as wide. plus the shaft can be cut down to the proper lengh, wich means i only have to buy the spacer.
The info you're looking for is right here in this thread. Post #14. I can't read all the text right now, but I think I gave the amount to cut off. You have to be using a 6in passenger car Th350 output shaft. Can't do it with the 9in truck shaft because then your run out of splines. Let me know if that answers your question or not.
TIC
east Tennessee
K1500
350cid
i found a spacer kit with no shaft you can view the instuctions on pdf it said to get a shaft out of a car tranny with a 6in tail and measure from the center of the speedo gear clip hole out to 31/4in and wrap tape, and cut off 13/8in including the saw blade. now is the T/C bolt pattern the same for the 350 and 700r ?
TIC
east Tennessee
K1500
350cid
i went back and looked, couldn't find one word on how long the finished shaft was or how much you cut off.
JOD26
